跳转到主内容
加入维修社区 - 创建账户
2017 年 3 月发布,型号为 SM-J727
J7 Crown Black Screen
I have a J7 Crown S767VL that has no screen display it stays black phone is still powered on and when I try to hard reset it doesn't fix the issue I have tried to power off by holding power + volume down button for 20+ seconds and after about 15 seconds of holding buttons it vibrates every 1-1.5 seconds and does not power off. I have been attempting to factory reset with black screen with no luck and have exhausted my options available online. Please give me suggestion(s) on what I can do it is a straight talk phone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
It sounds like an LCD fault. Has the phone been dropped in water or dropped on a hard surface?
这个答案有帮助吗?
得分 0
12条评论:
I do not believe it has gotten wet or dropped, it is in pretty pristine condition as far as I can tell I was thinking it was a corrupted firmware issue
由完成的
You will need a new LCD if you haven taken phones apart then you can replace the screen yourself or take it to a repair shop. It will be a whole lot cheaper replacing it yourself if you do that go here https://www.amazon.com/Replacement-Digit...
由完成的
Is there a way to try to perform a factory reset without the ability to boot in recovery mode and being unable to do it through settings?
由完成的
Hope this helps
由完成的
Yes if you have a computer
由完成的
显示更多的7条评论
添加一条评论
添加你的答案
Corbin Dallas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 1,941
