跳转到主内容
Televisions made by the Chinese multinational electronics company, TCL.
263 个问题 查看全部
TCL Half of screen darker
do I need to replace leds when screen darker on half of tv
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
Sherri B  it is possible that this is an LED backlight array issue. Post some images of what your screen shows. Use this guide 在已经存在的问题里加入图片 for that. You also want to try to reset it. Remove all input sources as well as soundboard etc. Then unplug the TV. Either hold the power button down for a few minutes or keep the set unplugged for something like 30 min. Then connect only one video source ( a local source like DVD/BR/ or Game console would work. Stay away from cable or sat box for now since they can actually be part of the problem).. Then plug the TV back in and see if that made a difference. If it did not you will have to remove the back cover from your TV and take a look at the board. Check for any obviously damaged looking parts and reseat the interconnect cables. Post some pictures of the boards as well. You will need a multimeter to check the LED connector voltages etc. TCL is still a bit of an off-brand make so there are not a whole lot of schematics etc. available so we need to rely on your images to see if we can find out what's going on.
这个答案有帮助吗?
得分 3
添加一条评论
May be? Just open and see if there are any “leaked capacitors”…
这个答案有帮助吗?
得分 0
添加一条评论
I repaired a 43P20US TCL smart tv right side darker and eco setting on would make the screen go black at 4 sec intervals. Checked power supply okay. Secondly I decided to go straight to TCON board it was pretty dusty so decided to clean connections with pencil eraser. Retested and solved both issues. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
left screen is darker coler good. just got replacement boards from shopjimy.tv works but still darker left screen.i do think the tcon board was bad.it is a better pic……but no lines in the screen just little darker on the left.the new boards and all was replaced pic not disorteing now…is the update bad??????????????????????????????
这个答案有帮助吗?
得分 0
1条评论:
yep might be just that///////
完成的
添加一条评论
添加你的答案
Sherri B 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 11,808
