跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
back separated and battery appears inflated
This iPhone 4s had been asleep in my wife’s purse for a while . When I removed it to charge it I discovered that the back had separated from the body and the inner back was separated somewhat from the outer. After removing it I discovered the iFixit battery I’d installed some time back seemed to have “inflated” somewhat and was likely responsible for pushing the back away from the chassis. I have two questions: 1) what was the likely cause of all this and 2) can I repair it with a new back and battery? I’ve attached a photo which helpfully shows the problems.
https://www.flickr.com/gp/rdmoran/6t3Tn7
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Batteries can fail and swell up. Very common. Just replace it. If it is less than a year old iFixit will replace it for free.
iPhone4s 电池更换
这个答案有帮助吗?
得分 3
5条评论:
Thanks. It's surely more than a year. What about the separated back which I guess the inflated battery caused? Does the back replacement include both the inner and outer part?
完成的
I should add that strangely enough, though the iPhone appears "broken", it works quite well.
完成的
I'm not a seer, open it up and repair what you know has failed first then we can talk about other damage.
完成的
Well if the back glass has separated from the removable plastic metal ish back cover then the back glass will need to be replaced.
Generally with bloated batteries they are supposed to drain significantly quickly due to it going bad.
完成的
Thanks to all. I'm going to replace the back and the battery.
完成的
添加一条评论
添加你的答案
Robert Moran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 90
