跳转到主内容
三星公司于2018年3月发布的旗舰手机,盖乐世 S9。
137 个问题 查看全部
Why is the battery draining while charging?
My sister's phone drains while charging. It will usually go up to 31%, but then later it goes down. I find nothing wrong with phone, charger, or outlet. I can't seem to find the solution to fix this. I have tried everything from cleaning the phone to restarting the phone a couple times.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi,
What happens if you charge the battery with the phone switched off?
Does it charge to 100%?
If so how long does it take to discharge with normal usage?
Have you tried installing and running an A/V (Anti Virus) or an anti-malware app to check if the phone has a virus or malware installed that may be operating in the background, thereby draining the battery unnecessarily? (Avast for mobiles and Malwarebytes for mobiles are two good free apps to try but there are others that may suit you better).
完成的
添加一条评论
1个答案
已选择的解决方案
Not an easy solution here, as it might be a bad charger, which should be easy to rule out wit any other charger you have around with a Usb port.. or a bad battery, if the replacement charger doesn’t fix the issue. Replacing battery is a bit more troublesome, but it can be done, have a look at the guide. Last possible reason would be the charging circuit, but that’s not a DIY job, you’d need to find a Pro for that.
三星 Galaxy S9 更换电池
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
catherineuzumaki 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 47
总计 7,310
