跳转到主内容
The Alienware M14x is a laptop designed for optimum gaming experience and content.
2 个问题 查看全部
Laptop GPU reflowing- help needed
Hi I want to reflow the gpu on my only laptop by myself, I can't trust repair center or can't effort a new laptop .
I kind of bent the main board so this happened.
Question : I want to reflow gpu using heat gun and laser thermometer for measurement , what's the best melting temperature for it? I saw people go up to 260 but I usually solder joints melt at 200-210 Celsius , so I'm wondering if lower temperature will reduced the risk of burning the gpu completely…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@javid_zare_s a reflow is not going to fix a bend motherboard. If the solder connections or pads have come loose they will not go through a reflow. Remember that a good reflow is more than just blasting an area with a hot air gun. Anyhow, I suggest you follow the profile as outlined on here
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Javidzed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 8
总计 433
