跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
HDMI Repair Difficulty Level
I am about to buy a ps4 with a broken HDMI port, in order to attempt a repair. I have this soldering kit: https://www.amazon.ca/gp/product/B07CJQ7...
I have soldered things here and there, mostly on my computer, but I am by no means an expert. Is this repair advisable given my equipment and my skills?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
That's a through hole repair, it's going to be a very tough job and you won't go very far with just that soldering kit. You would need to add at least a hot air station as solder has to melt evenly on both sides of the board. Unless one has a preheater, even the hot air station alone can hardly be sufficient and the risk to overheat one side before melting temperature is reached on the opposite side should be considered.
完成的
添加一条评论
1个答案
Hi Jules,
try to compare your skills with following video and judge, if you are responsible to solve your issue.
这个答案有帮助吗?
得分 0
2条评论:
Hi,
I've never done anything as precise as the contact pin soldering in the video, so I'll probably pass.
完成的
@Jules Bong Depending on your choice :)
完成的
添加一条评论
添加你的答案
Jules Bong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 29
总计 1,369
