Hot water leaks when filling
I have a 110 82872800 machine that leaks hot water when filling. It doesn’t leak when I set it to cold water and it doesn’t leak when spinning. The water comes primarily out of the bottom on the right side of the washer and sometimes from the front.
I’ve taken to running the hot / cold water cycle first for my whites and then switching to cold / cold for the colors. There’s no further leaking when running the cold / cold.
There’s no leaking at the water faucet connections.
I’d rather not replace the unit if it’s just a matter of changing out a hose. All the guides I’ve seen thus far aren’t specific about the hot water only problem.
Thanks!
