跳转到主内容
加入维修社区 - 创建账户
An Android smartphone produced by Samsung released in January 2017.
Why is my phone not charging and giving off a burning smell?
I have a Samsing Galaxy A5 (2017). One day it stopped charging and when plugged in, a burning smell is released from the charging port. The other end of the cable also gives off a burning smell. Any solutions, or advice on what I should replace? Also, what is the best adhesive/tape I can use to install the acrylic back after removing it? I’m looking for some adhesive that I can find somewere like bestbuy or walmart.
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
If my charging port smells like burning how do you stop it from burning
完成的
My galaxy a01 charger port smells like it's burning and this greasy stuff is on the back of my phone what is it? and what should I do?
完成的
How do I get it to charge again?
完成的
添加一条评论
3个答案
最有帮助的答案
@thestrangeslav something on your charging circuitry went array. You want to go ahead and stop trying to charge it etc. Then you want to go ahead and disassemble your device. Start this by using these guides Samsung Galaxy A5 (2017) and/or this video Then check your circuit boards for obviously damaged components etc. Post some good pictures of your boards with your QUESTION. That way we can see what you see. 在已经存在的问题里加入图片
After that follow the troubleshooting steps as suggested on here
The connector IFC6001 is available at places like this
这个答案有帮助吗?
得分 1
添加一条评论
if you smell a burning smell at both ends of the cable try a different USB Adapter and see what it does. on the samsung galaxy a5 it does not use adhesive, the screen just clips in.
这个答案有帮助吗?
得分 0
2条评论:
Actually this model the screen is held by very strong adhesive. There is also adhesive for the back glass.
It sounds like the USB-C charging socket on the phone needs to be replaced. This is quite difficult to do as it is soldered onto the logic board. This I would leave it to a local reputable phone repair shop to get it fixed.
First thing to do is try another wall charger and cable if you still smell the same electrical burning smell it means the problem is with the charger port instead.
完成的
go look up a disassembly on a samsung galaxy a5
完成的
添加一条评论
if you smell burning it was caused by electricity and is melting/ burning something change USB adaptor see if that works if not change the charging board in the phone.
这个答案有帮助吗?
得分 0
1条评论:
Ayden Aldrich so what's the fix? How can you help the OP repairing his device? How does your answer help the OP?
完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 33
过去 30 天: 190
总计 37,222
