跳转到主内容
2010 MacBook Pro system report says no battery present
when i unplug my 2010 macbook pro it will turn off, i have done an smc reset and pram reset, it doesnt show the battery icon at the top of the screen either. I have searched around the internet for any fixes and none helped.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
On the left side of the uppercase body is a battery checker how many LED’s do you see lighting up?
这个答案有帮助吗?
得分 1
6条评论:
no LED's light up
完成的
Then your battery is not charging or is bad. What does the MagSafe LED show you Green or Amber when you plug it in?
完成的
the magsafe is always green
完成的
and i added a picture of coconut battery
完成的
You need a new battery ;-{ The microController within the battery is not working and as such the battery can't get charged.
Here's the needed battery MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery and here's the guide MacBook Pro 13" Unibody 中期 2010 电池更换
完成的
显示更多的1条评论
添加一条评论
最有帮助的答案
Please use a better tool (free) Coconut Battery and post your results.
https://coconut-flavour.com/coconutbatte...
这个答案有帮助吗?
得分 1
2条评论:
okay i will download the program and post the results when i get home
完成的
the picture of coconut battery is up on the question
完成的
添加一条评论
添加你的答案
Vipaha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 54
