跳转到主内容
加入维修社区 - 创建账户
Guides for the LTE version of the iPad Mini 4—model A1550. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
New display didn't come with accessories
I'm replacing the display on an iPad Mini 4. The original one was demolished and the home button was actually missing. I ordered the replacement screen from AliExpress among with a new home button, but neither came with the home button “riser” (thin plastic ring that goes on the glass first). Could I use one from an earlier iPad Mini?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
That “riser” thing is generic, you can transfer from any iPads. What you also need is a rubber gasket which doesn’t usually come with replacement home button
iPad 5/6/Air 2/mini 4 Home Button Gasket
You can get it cheaper elsewhere, or use salvaged ones with right cut-out
Replace the adhesive gasket that holds the home button face onto the back of the front panel glass compatible with an iPad 5, iPad 6, iPad Air 2, or iPad mini 4.图片
产品
$1.99
这个答案有帮助吗?
得分 1
2条评论:
I would also add to remember to transfer magnets from the old to the new screen, they might go unnoticed unless one did the job before.
完成的
@arbaman good point! transfer magnets, sleep/wake sensor, etc. from old screen if new screen doesn't have them pre-installed.
完成的
添加一条评论
添加你的答案
Bill Shannon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 177
