跳转到主内容
Clothes still wet after spin cycle
WA40J3000AW/A2 Top load Samsung washing machine will get stuck on the spin cycle and will leave the clothes wet. Sometimes taking out a few articles of clothing and restarting will allow the washer to complete the spin cycle. However this issues seems to be getting worse and worse.
We went to Lowes to see if we could get someone to check on our washer but they said it would be cheaper to buy a whole new washer. I want to try my hand at fixing it before I resort to that. Does anyone have any ideas on a potential solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
xxjwiles17xx you are aware of the recall on this washer due to the " top can detach unexpectedly from the washing machine chassis during use, posing a risk of injury from impact. "
完成的
添加一条评论
1个答案
已选择的解决方案
xxjwiles17xx  this “Sometimes taking out a few articles of clothing and restarting will allow the washer to complete the spin cycle.” could be a motor issue as well as a clutch issue. If the washer does not spin fast enough the laundry will remain fairly wet. The other thing to check is the drain pump. If it is clogged or partially clogged the water will not leave the drum and thus the laundry will remain wet.
WA40J3000AW/A2 Clutch
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
xxjwiles17xx 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 23
过去 30 天: 118
总计 4,675
