跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for Kenmore Microwaves.
Microwave lost light /display
Kenmore microwave model 40185043310. Was wiping out interior with wet papertowel and all of a sudden the light and display went out. Unplugged and still nothing on plugging in again. The strange thing is when i hit the upper rear area inside the light and display came on and it beeped. When I removed my hand though it disappeared again. Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@ckpa that is the general area where your capacitors and transformers are located. You may consider removing the outer cabinet to see if your MW has some loose connection etc., just do not touch anything and have your MW disconnected from the power supply when you consider working on it. It packs a punch and can easily zap you pretty good. If you unsure of doing any of this I would suggest you take it to an appliance repair shop and have them look at it. MW are not the ideal appliance to work on for the less than novice DIY’er
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Carolyn Krammes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 163
