跳转到主内容
The Sony Xperia XZ1 Compact is a compact flagship Android smartphone from Sony released in October 2017.
11 个问题 查看全部
Is it ok to glue the xz1 compact top lid?
The thin metal piece at the top of the phone detached from the phone after a fall. Everything still works fine, but still, i’d rather have it attached. Is it ok to glue it, and if so, what type of glue should i use ?
Thank you !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@anoyo anytime you need to glue something back, you want to make sure you are using an adhesive that will allow for future disassembly if so desired. I prefer to use epoxy adhesives like Gorilla Epoxy etc., personal preference for sure. If you do not to take it ever again apart remember that you require heat to do so :-)
这个答案有帮助吗?
得分 1
2条评论:
Well, for me the lower lid deattached. What can I use to attach it back in, the phone works just fine. Anyways, what can i use and where do i buy expescially for the Sony Xperia G8441??
完成的
@Luccafo I'd be using E6000
完成的
添加一条评论
添加你的答案
Anna Onymous 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 291
