跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
Battery drainage due to motherboard issue
My samsung galaxy s8 battery drains very fast,even in idle mode.
Customer care service says,its an issue of motherboard,battery replace will not solve this.
How can i fix or refresh motherboard without repairing it?
NB: phone overheats during charging.
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@jnemon I am not sure who your Customer care service but you do want to start with a new battery first. You cannot proper troubleshoot without doing that. If that does not change anything you will have to troubleshoot the charging circuit. So start with a known-good point like a new battery
这个答案有帮助吗?
得分 1
添加一条评论
Hi @jnemon
PMIC is a common failure for the Samsung S8 series. The typical failure will eventually result in the phone being completely drained and unable to turn on at all (its a good time for you to check the back-up settings).
Here is the replacement process for this chip: https://vimeo.com/274029552
If you aren’t comfortable with this repair, you can get the logic board replaced through any Samsung Authorized Service Provider. If your phone is still under warranty, there would be no cost associated with the replacement.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Life is BEAUTIFUL 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 1,640
