跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Why is my phone screen unresponsive after being replaced
I recently dropped my iPhone 7 and got a crack. It was working completely fine even after the crack but after it was fixed I am finding that certain places on the touch screen are unresponsive. Does anybody know why?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
This could be caused by an improper installation or a partially defective replacement screen. If you installed the replacement screen yourself, take a look at this guide and double check your work. If it is properly installed, you could try your original screen to see if it has the same issue or not. If the problem only occurs on the replacement screen, contact your vendor/supplier.
If the phone was repaired in a shop, go back to see them and they will resolve the problem.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Zoe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 41
