跳转到主内容
The Sony Handycam FDR-AX33 is a palm sized camcorder that combines 4K video with video stabilization. It was released in March 2015, and was the first camcorder to introduce the new Balanced Optical SteadyShot (BOSS).
7 个问题 查看全部
How to fix a lens in this camera sony ax 33
е: ошибка 61: 30
Как исправить объектив в этой камере. Второй раз за 2 года он ломается. Петля была изменена в камере уже. А потом обратно.
Где находится этот цикл и как его заменить?
Google translation
e: error 61:30 How to fix the lens in this camera. The second time in 2 years it breaks. The loop has been changed in the chamber already. And then back. Where is this cycle located and how to replace it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Top Device error E: 61: 30 means issue of the lens driving part. this “The loop has been changed in the chamber already. And then back. Where is this cycle located and how to replace it? “ seems to get lost in translation. I attached the disassembly part of the manual to the answer so you can hopefully find what you are looking for. Sony FDR-AX33 Disassembly
这个答案有帮助吗?
得分 2
添加一条评论
Hi, I have the same problem in my FDR-AX33 Error E:61:30.
The description gives me problem with “Issue of the lens driving part”
Can you help me identify which part or parts are necessary to exchange?
Rgds
Miguel Silva
这个答案有帮助吗?
得分 0
添加一条评论
Hello,
I´m with the same problem on the same camera AX-33 error E61:30. The sceen is white with some noise.
I will try to get a quote from Sony or someone can help?
Regards.
MS
这个答案有帮助吗?
得分 0
添加一条评论
Same Issue at my Camera, no solution ahead?
这个答案有帮助吗?
得分 0
添加一条评论
ME DA LA SENSACIÓN QUE ES UN ERROR PROGRAMADO.
LE HE DADO SIEMPRE UN TRATO EXQUISITO Y DELICADO Y DE LA NOCHE A LA MAÑANA ME DIÓ EL ERROR E:61:30
NO ENCUENTRO QUIEN ME ORIENTE, SOLO LLEVARLO AL SERVICIO TECNICO.
MI EXPERIENCIA EN LOS SERVICIOS TECNICOS ES QUE LO REPARAN Y AL POCO VUELVE A FALLAR CON EL COSTO ALTO DE PERITAJE Y DESMONTADO. Y LA DUDA DE SI NO LO QUIERES ES COMO VENDRÁ …
DICEN QUE ES QUE CADA CIERTO TIEMPO, HAY QUE HACERLE REVISION DEL MECANISMO DE DESPLAZAMIENTO DE LA LENTE QUE POR SUCIEDAD SE ATORA (CLARO LLEVÁNDOLA A UN SERVICIO TÉCNICO Y A PAGAR).
ESTOY PENSANDO UNA NUEVA PERO CAMBIARÉ DE MARCA CON MÁS CONFIANZA.
EN ESTA TENÍA FE PERO YA NO ME FIO.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Top Device 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 1,707
