跳转到主内容
加入维修社区 - 创建账户
Nimbus 是一款 2016 年发布的无线游戏手柄。它专为兼容 iPhone、iPad、iPod Touch、Apple TV 和 Mac 而设计。
A button not working
A button not workimg
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My steelseries nimbus button “B” not working
由完成的 分享
添加一条评论
1个答案
最有帮助的答案
If you have only just noticed some stickiness or you’ve just spilled something on your controller, you only need a minor cleaning around your buttons. Grab some Q-tips and some rubbing alcohol for this quick cleaning tutorial.
  1. First, unplug the controller.
  2. Dip the Q-tip into the rubbing alcohol, dabbing off any excess.
  3. Rub the Q-tip around the button that is sticking several times, getting as far into the crevices as you can.
  4. Once you think you’ve cleaned out as much as you can, press the button a few dozen times to work the rubbing alcohol into the crevice and loosening any debris left behind.
  5. If the button still sticks, repeat this process or try another method lower on this list.
Rubbing alcohol evaporates quickly and you shouldn’t be using enough to do any damage to the circuitry inside the controller. Never clean a controller with water as it can get inside and cause corrosion and circuitry damage to the controller.
Lewis
这个答案有帮助吗?
得分 3
2条评论:
Great.. Its working!!
Thank a lot
由完成的 分享
can you mark it as an answer? Thanks.
由完成的 分享
添加一条评论
添加你的答案
Scott Okada 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 2,027
