跳转到主内容
加入维修社区 - 创建账户
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
Does probe points matter?
Hello I have a question, I wonder if all these probe points (I mean clear pads on motherboards, in iPad air 2 these pads are on bottom side of motherboard) matter ? Will be there any problem if I sudenly rip one of these pads off ? I have a motherboard with 2 ripped pads and it doesn’t work and I wonder if this motherboard isn’t working because ripped 2 pads or they don’t matter at all and I have to search somewhere else ?
PS: photo doesn’t shows my broken board, I put it just to show you what pads I have on my mind.
Thanks for any help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
sofles we would need to see YOUR board to see what possibly could be damaged.
完成的
添加一条评论
1个答案
已选择的解决方案
On bottom side of the iPad board, beside probe points there is a number of passives, resistors and capacitors, I’d be inclined to think if pads have been ripped off there might have been something attached to it. Hard to tell without any testing, but a missing resistor may be enough to cause a failure.
这个答案有帮助吗?
得分 2
2条评论:
I have checked and there is nothing, just clear pads. two of them are ripped of the board and I can see veeeery tiny pin in the middle but bottom larger pin is ripped and that's why I wonder if these pins are just for measurement or they are connecting traces ?
完成的
@sofles I can't really figure out the extent of the damage without a picture. In principle if it's just a probe point it shouldn't cause any issue.
完成的
添加一条评论
添加你的答案
sofles 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 122
