跳转到主内容
加入维修社区 - 创建账户
My car won't start.
Hello there
I parked my car yesterday and after two hours came back and my car was not starting. Everything was normal the lights, windows and even radio. So I am quite sure its not battery. I removed some fuses and put them back but didnt work.
Wondering if anyone have a solution or at least know what the problem is.
Modell: c3 1.1 2004
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
10条评论:
@mk1234 you turned the headlight on and tried to start. Do the headlights go dim (mer) or stay as is? Automatic or standard? If automatic have you tried ion Park and in Neutral to start?
完成的
Well Its manual and I tried both neutral and 1. Didn't work.
完成的
Does your light turn dim when you try to start your Citroen?
完成的
have you fuel in the car silly questiion maybe but you never know
完成的
When you try to jumpstart your car, do you hear a loud clicking noise?
完成的
显示更多的5条评论
添加一条评论
1个答案
Its been awhile since you have asked for help with no additional information given, you need to know if you are getting gas into the cylinders, typically if a spark plug smells like gas, that may be good. you need to know how to inspect for spark with a spark tester, any parts store should sell one and tell you how to use it or watch a video online. When you try to start does it sound normal or does the engine seem to turn over much faster than before, or strange sounding between each cylinder compression stroke then you assume you have a jumped or broken timing belt, if your car is a belt or chain??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mmk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 4,900
