跳转到主内容
Model A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Compatible memory for iMac 2012?
Hi,
Can I put in my late 2012 iMac 16gb ddr3 1333 MHz memory instead of 8gb ddr3 1600 MHz installed?
I know that is speed downgrade.
Cheers
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Your machine uses:
RAM Type:PC3-12800 DDR3*Min. RAM Speed:1600 MHz
Details:*By default, this system has 8 GB of 1600 MHz DDR3 SDRAM. Apple does not intend for one to upgrade the RAM in this system. However, as first discovered by site sponsor OWC, this system has two SO-DIMM slots (204-pin). Unfortunately, accessing these slots requires one to pry off the display that is glued to the case and remove the logic board.
Standard RAM:8 GBMaximum RAM:16 GB*
Details:*8 GB of RAM is standard and it could be upgraded at the time of purchase to 16 GB for an additional US$200. Although Apple does not intend for one to upgrade the RAM after purchase, and doing so is difficult, it is possible.
https://everymac.com/systems/apple/imac/...
这个答案有帮助吗?
得分 2
添加一条评论
Your system uses 1333 MHz PC3-10600 DDR3 SO-DIMMs.
1333 MHz SO-DIMM’s are the correct RAM. It’s getting harder to find these slower SO-DIMMs. 1600 MHz SO-DIMM’s will also work.
Apple didn’t make getting to the RAM easy! Here’s the iFixit guide iMac Intel 21.5" EMC 2544 RAM Replacement as you can see its quite a bit of work. I would strongly recommend getting the iFixit tool kit with the needed pizza cutter and adhesive strips for the display iMac Intel 21.5" EMC 2544 (Late 2012) Memory Maxxer RAM Upgrade Kit
Max your iMac Intel 21.5" EMC 2544 (Late 2012) with 16 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your iMac.图片
产品
$139.99
这个答案有帮助吗?
得分 0
3条评论:
Thanks for your response.
I think my iMac late 2012 uses 1600 MHz!
Now there are 2x 4GB 1600 MHz installed.
My question is : Is 2x 8GB 1333 MHz will be compatible with my iMac late 2012?
完成的
@danj you may be wrong on this one
完成的
Yes, I goofed! I clicked on the wrong URL my bad!
Here's the correct info iMac "Core i5" 2.7 21.5-Inch (Late 2012)
完成的
添加一条评论
添加你的答案
hal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 1,408
