跳转到主内容
The Astro A40 TR Headset is an audio device released in August 2015, identified by model number 3AS48-XOU9N-601
Can I replace or repair these cables?
can I repair these cables?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
lucasmano96 I am certain you can. Since you did not tell us which wires and why you think you need to repair those, check the guides and see how the wires are attached to the inside of your headset
Astro A40 TR
这个答案有帮助吗?
得分 2
3条评论:
So the wiring through the head band got de attached. The one that runs through the headband and I’m not quite sure how to fix it.
完成的
Or if it’s fixable
完成的
@Bryce Bender detached how or where? Is it the same headset?
完成的
添加一条评论
添加你的答案
lucasmano96 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 13
总计 1,262
