跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
Battery exploded is my Logic Board functional(PICTURES)
I was trying to fix the back glass of my iPhone 8 Plus when I poked the wireless coil going through the battery and There was a loud hiss than smoke started coming out the battery was connected and it just destroyed the screen it poked out the back glass I managed to get everything out after it cooled down now I just want to know is my logic board possibly still functional so I can just buy a new housing battery and screen and possibly put it back together I have attached pictures just because I don’t have another phone to try it with!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Cassandrew Delicieux  “Aren’t the electronic compounds under the black” you are absolutely correct. So the first thing I’d do is remove all of those shields and covers. After that clean the board with some isopropyl and a soft toothbrush. Use this guide 修复iPhone 的进水故障 to clean it. Once cleaned inspect the logic board for any missing or charred components and post some good images of your board with your question. Right now it is all a guessing game.
What is that last pictures side view of?
这个答案有帮助吗?
得分 2
添加一条评论
Your logic board is molten in the edges, and the electronic components are burned, sorry your motherboard is out of use.
这个答案有帮助吗?
得分 1
2条评论:
Aren’t the electronic compounds under the black how do you know that they are burned in just curious you know don’t wanna throw away $200
完成的
Tiny electronic components are sensitive to heat, their proprieties will easily change when you heat them up, of course there is a safety margin and they can recover after cooling down, but I think the battery has made a strong heat wave and caused irreversible damage.
完成的
添加一条评论
添加你的答案
Cassandrew Delicieux 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 183
