跳转到主内容
加入维修社区 - 创建账户
HP Officejet Pro 8600 Plus 可以通过其型号 N911g 进行识别。该打印机于 2011 年发布,其外观为棕色,并配有触摸屏控制面板。
What is a printer failure?
It said “printer failure,” but I don’t know what happened that caused it. It said,
Printer Failure
There is a problem with the printer or ink system. Turn printer off, then on. If problem persists, contact HP.
Then I took pictures:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Evan, have you received any offline replies? I have this exact issue with my OfficeJet Pro 8600 Plus, using my Mac that's running OS X 10.14.4. I've done all of the suggested troubleshooting too, and now I can't even run the HP EasyStart app to check if the firmware is up-to-date b/c even tho the wifi icon is lit up on the display, EasyStart can't find the printer on my network. And I can't get beyond the "printer failure" message on the display...!
由完成的
添加一条评论
1个答案
Sure looks fine internally.
Have you tried the troubleshooting steps on HP’s support site? My gut tells me there might be paper stuck in the duplexer. I’ve had that same model printer and it seemed like it was getting choked with paper constantly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Evan Lei 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 1,600
