跳转到主内容
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 个问题 查看全部
Can I plug in a 135w xbox 360 adapter on to 750w voltage transformer?
Before I played XBOX360, I was worried about the amount of voltage.  The amount of volt and watt of XBOX360 is 100 ~ 127V–3.7A, 47 ~ 63Hz Input AC 135W 12V 10.83A, 5Vsb 1A Output DC.  But the transformer is 750W input AC 220V output DC 110V.  so, it is okay to connect the xbox 360 adapter to that voltage transformer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@justagamer24596 not if your transformer puts out “output DC 110V “! It should be AC voltage that your Xbox power supply plugs into. If it was AC voltage then yes, you can use is.
这个答案有帮助吗?
得分 2
4条评论:
@oldturkey03 the voltage transformer says:
Volt- Amps = 750 W
Cycles = 60
Volts input = 220V
Volts output = 110V
If i plug the voltage transformer in here(200~240V), it will convert to 110V.
So can i plug my 100~127V xbox 360 adapter in the voltage transformer?
But my biggest problem is, the watts of the xbox 360 adapter had a 135w, then the voltage transformer had a 750w, it will destroy my adapter if i plug in?
完成的
@Takumi Terui oh I see what you are looking at. No, it will be okay. The wattage is pretty much just the amount of power it will pull from the transformer. The transformer delivers up to 750 W but your xbox will only pull 135 W from it. You are okay with it. Not sure what country you are in but you might want to start looking at a Xbox power supply for the higher voltage. something like this https://www.amazon.com/Microsoft-Origina... for example
完成的
So it means i can plug in my console adapter to a voltage transformer?
完成的
Yes it does mean you can use it
完成的
添加一条评论
You are using a step down transformer, if you wish to plug more items into it, probably via a multi plug extension cord, you can add more items up to 750 watts, just don’t plug the toaster and the microwave in and use them at the same time LOL.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Jayzee Fury 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 675
