跳转到主内容
加入维修社区 - 创建账户
第二代 Buick Lacrosse 经过从零开始的重新设计,显著提升了品牌定位,成为 Buick 的旗舰级大型豪华轿车。
installing new front struts
when installing new front struts do you remove nut holding spring after installation
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Depends on your parts and installation procedure.
Absolutely DO NOT remove the nut! That nut, if we are talking about the same thing, should only be removed after using spring compressors in order to remove or replace a spring and extreme care must be taken to avoid personal injury. The nut also typically secures the main shaft of the plunger inside the strut tower that allows the strut to further dampen bumps from the road.
Full or quick struts are typically installed as a unit or assembly and should only require it be bolted into place with proper torque. Occasionally this requires an alignment depending on the vehicle and the strut.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Grossman 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 13
过去 30 天: 32
总计 942
