跳转到主内容
加入维修社区 - 创建账户
a7R II(型号 ILCE‑7RM2)是索尼 2015 年推出的全画幅、微单、可换镜头相机。
Menu scrolling through itself like crazy
My Sony A7S Mark 2 is moving the menu by it self please how do I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
hi, i have the same problem with my Sony A7ii. Menus switching on its own and sometimes goes back to normal then switching and scrolls again.
Did you already FIX yours??
Thank you :)
由完成的
Same problem. Any help?
由完成的
Me too. Anyone sort it?
由完成的
Very late reply. Got mine fixed at the nearest camera repair shop for USD65.
They say this is a common problem with Sony A7II after sometime...
由完成的
Hi. Did they say what the problem was that fixed the camera? 65$ is pretty affordable. Thanks
由完成的
添加一条评论
2个答案
最有帮助的答案
Hey, Shakily_17
The issue could be that you need to replace the buttons, but it's likely that a ribbon cable isn't fully connected or it is damaged. This issue can be found in other devices such as the Sony Dualshock 3 and the Asus Zenbook.
这个答案有帮助吗?
得分 2
添加一条评论
Sounds like a "Stuck Button" Problem. Common with most devices that you use the buttons, when they aren't cleaned they can stick. Even if the "External Buttons", or the button layovers, are cleaned, the internal buttons may be dirty. Try cleaning the buttons with Isopropyl Alcohol, and a soft electronics towel. If that doesn't work, check the cables and clean the internal buttons and cables if necessary.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
shaikly_17 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 50
总计 1,737
