跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 个问题 查看全部
How to remove hard drive?
I don’t have the manual anymore for this computer, but we went with a new pc and I need to make sure our banking data, etc. is gone for good on this old Mac. I unscrewed a plate at the bottom of the unit that had 3 screws in it and all I can see is 2 thin plastic tabs that can be pulled out, but when you pull on them, nothing is moving. Can this be done? I don’t see anywhere else on the body of this where I can open anything. Thanks for any help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论:
Please look on the bottom of your stand and give us your Axxx number and your EMC number so we know what you have and can advise you.
完成的
Hi mayer, I may even have the wrong model, but it looks the most like the one pictured.... The EMC number is 2308. I don't see an Axxx number, but I do see the model number is A1311.
完成的
You have a
Apple iMac "Core 2 Duo" 3.06 21.5-Inch (Late 2009) Specs
Identifiers: Late 2009 - MB950LL/A* - iMac10,1 - A1311 - 2308
完成的
Great, thanks for that; yes, it's "that" old!
完成的
@dedou1 BTW we can probably help you get this machine running for less than $75. and probably $38.64. If you don't need it, I'm sure you know a kid that would love to have it.
完成的
显示更多的2条评论
添加一条评论
2个答案
You have a:
Here’s how to do it on your model:
iMac Intel 21.5" EMC 2308 硬盘更换
这个答案有帮助吗?
得分 0
4条评论:
I think both anwser are OK @mayer has you can also install an SSD and it may have either
完成的
@gueser Totally incorrect!
完成的
@mayer Step 18?? is this not an SSD
完成的
@edigitcom Read the question! He wants to wipe his data.
完成的
添加一条评论
Hello
There is not a phical hard drive in this model
There is a Solid-state drive (SSD)
Hope this link will help
iMac Pro拆解
这个答案有帮助吗?
得分 -1
4条评论:
@gueser Please learn to get the facts before answering.
完成的
@gueser The OP listed this as a iMac Pro to begin with. After reading his question, it was obvious that was not what he had, so I asked for his EMC #.
I then knew what he had. Your answer is totally incorrect. Now the question was about how to destroy his data on a dead machine. Your answer makes no sense in light of the actual problem and machine.
完成的
Hey thanks to both of you for your help. I got brave and took off the front glass, then got to work with all those screws. I am sitting here now with a Seagate Barracuda 500 Gbytes drive, and what looked like an SSD as well (I think that's how you say it). All the rest I poked around in and I think I got what would be potentially useful to anyone trying to access my old data. This site is great and I appreciate the quick help. Women weren't taught this stuff when I was in school!
完成的
完成的
添加一条评论
添加你的答案
Devon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 386
