I get ink smudged down edge of paper when printing
When printing, there is smudged ink from the cartridge down the edge of the paper every time I print.
Hi Mark, what had you tried?
Had you tried checking on the toner?
Do you have a spare toner? If so, install and print again. Observe the results
There are some possible reasons why you are getting this….
Share with you on the links below for an idea:
这个答案有帮助吗?
your catriage may be over filled.
your catriage may have encountered problems, may need replacement.
try checking the catriage cleaner to know if it is over soaked then clean it
这个答案有帮助吗?
过去 24 小时: 6
过去 7 天: 13
过去 30 天: 28
总计 1,723
