跳转到主内容
Repair guides for the HP LaserJet 1160/1320, a laser printer made by HP. The LaserJet 1320 has a duplexer and networking options, but the LaserJet 1160 does not.
11 个问题 查看全部
I get ink smudged down edge of paper when printing
When printing, there is smudged ink from the cartridge down the edge of the paper every time I print.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi Mark, what had you tried?
Had you tried checking on the toner?
Do you have a spare toner? If so, install and print again. Observe the results
There are some possible reasons why you are getting this….
Share with you on the links below for an idea:
https://smallbusiness.chron.com/causes-l...
https://www.printertechs.com/printer-tro...
这个答案有帮助吗?
得分 2
添加一条评论
Just buy “paper path cleaner” sheet and use as directed until prints cleanly
这个答案有帮助吗?
得分 1
添加一条评论
your catriage may be over filled.
your catriage may have encountered problems, may need replacement.
try checking the catriage cleaner to know if it is over soaked then clean it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 13
过去 30 天: 28
总计 1,723
