跳转到主内容
The second generation of the Samsung Gear, a round smartwatch running Samsung's Tizen smartwatch OS. The Gear S2 was released in October 2015.
The back cover keeps coming off
The back of my watch keeps falling off. Looks like it was held together with some sort of adhesive.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
9条评论
FWIW, the battery tutorial linked below doesn't mention any adhesive
Samsung Gear S2 Battery Replacement
Might want to closely examine the unit for broken locking tabs, maybe.
完成的
So the part I'm talking about is the part that is directly against the wrist, not after you open it to get to the battery. So if it falls off it exposes the gold part not the battery. It has a small window on it which is usually the sensor
完成的
@Jayne a Ahhh OK thanks for the update. Guess the sensor must be part of the charging system then, is that right? Being retired I haven't worn a watch in donkeys years now and so am not really up to date on the newer styled watches. Good luck with your investigations though. :-)
完成的
I have tried…seems like it needs some sort of adhesive glue to stay but not sure if I can just use regular gorilla glue
完成的
@propman thanks...so frustrating that they want to charge 70 dollars to replace the whole back but all I need is some glue...lol
完成的
显示更多的4条评论
添加一条评论
2个答案
最有帮助的答案
It appears to be a compression fitting. See if you can find someone with strong hands and thumbs to press it into place.
这个答案有帮助吗?
得分 2
添加一条评论
That worked! There was a notch where the dial was that I had to line up and then it took a lot of pressure around the outer edge of the metal back but I heard a few clicks as I pressed very hard around it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jayne a 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 4,458
