跳转到主内容
加入维修社区 - 创建账户
The Nikon D60 is a 10.2-megapixel Nikon F-mount digital single-lens reflex (DSLR) camera released in January 2008. The D60 is the successor to the entry-level Nikon D40x.
Spots on my photos, and my lens and reflctor are clean
What could the problem be? I was told it might be the sensor, but how do I clean that?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
you might want to check the Owner Manual for "bright spots" and how to reset the camera to factory default settings before attempting to disassemble your unit. A copy of the manual in PDF format can be obtained at the following link:
https://www.camerauserguide.net/nikon-d6...
完成的
添加一条评论
2个答案
最有帮助的答案
@kenuto if everything checks out than it is possible that this is caused by dust etc on the CCD sensor. Let us know if you are up to replacing it. Cost is around $70USD
这个答案有帮助吗?
得分 2
添加一条评论
Is your actual sensor clean? To get to it you have to go into the menu, select the wrench tab, scroll down to mirror lock up, enter that, click OK to turn it on, then you get a message about using the shutter button to lift it, then remove the lens with camera pointing down and you can use an air blower to blow the sensor off. once done, turn the camera off and replace the lens.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kenny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 529
