Yamaha PSR 730 mains cable required
Hi guys hope you can help me out here. The mains adaptor has stopped working as I can see a wire has come out near the connector plug due to wear and tear. I am having difficulty locating a replacement mains adaptor as the last adaptor I purchased just didn’t work. I think the issue is that the keyboard is a good 15 years old and the original adaptor is no longer available.
Would appreciate any ideas on how I can source the correct adaptor. Thanks
2条评论
https://infinisia.com/collections/batter...
Yamaha PSR-730
Input Voltage Range: AC 100V - 240V / Output Max: 12V 2A 5.5*2.5mm
The original Yamaha part is/was: PA-6
FWIW, there is really nothing special about that particular adaptor. Just pay attention to the voltage, current and connector size specifications. BTW, if you post a photo or two of your old broken unit, someone here should be able to tell you if it can be fixed or not.
在已经存在的问题里加入图片
由 prop man 完成的
@propman thank you for your reply. would this adaptor also work?: https://www.dawsons.co.uk/yamaha-pa150b-...
由 Rick 完成的
