跳转到主内容
加入维修社区 - 创建账户
马自达 Capella 在日本以外的市场通常被称为 Mazda 626。第六代 Mazda 626 基于 GF 平台打造,于 1997 年发布,属于 1998 车型年。
How do I replace lower ball joints?
I can't find any info on how to replace the lower ball joints on my 1998 Mazda 626
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It isn’t an overly easy job. You will have to remove or drop the lower control arm down and the ball joint will have to be pressed down and out with a shop press or borrow a ball joint press kit from an auto parts store.
There are tools you can borrow for free from Advance Auto and possibly AutoZone that give you the special sleeves and C clamp needed to manually press the old ball joint out and the new one in. Take extreme care during both removal and installation to ensure the ball joint is pressed out evenly followed by being pressed into the control arm evenly and flush. I’ve used the tool kit on my truck ball joints and it took every ounce of strength I had to turn the C clamp and press the ball joints out and back in.
It is recommended to have a service guide for almost any procedure to ensure you are applying the correct torque to the fasteners during installation.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
James Greenleaf JR 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 788
