跳转到主内容
加入维修社区 - 创建账户
雷达探测器的维修信息。
connecting to usb power source
Most detectors have a telephone style power cord connection. How can I connect to the USB power on my BMW motorcycle?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Might want to consult your radar detector's Owner's Manual to see if they mention the connector name and then use that to google for a "usb to <insert connector type here)" phrase. You also may want to edit your query to include the manufacturer and model of your radar detector to aid participants here in answering your queries.
由完成的
Haven't done this before. Amazed there are people out there actually helping out. I could have done the query better. I have an escort and a uniden radar detector with the usual telephone type plug for power in the detector. I also have a BMW r1200rt with a usb power connection, 12v, and a bike power connection like a small cigarette lighter. So, tried everything I could think of on the internet without success.
由完成的
It is not “USB” powered (which is only 5 volts.) The radar detector requires 12 volts to operate.
由完成的
添加一条评论
1个答案
已选择的解决方案
If I correctly understood, you would like to place a USB port on you motorcycle, in that case you need to step down your battery voltage from 12V to 5V using a regulator, or you can buy a converter like this one :
But you need to make some modifications, the best solution is to put a power bank in your pocket.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert Vasconcellos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 35
总计 2,392
