跳转到主内容
The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
66 个问题 查看全部
Why does my brake pedal go all the way to the floor when pushed on?
I have a 2001 Toyota Camry. I recently had to have a new brake booster installed about 4 weeks ago. Car was driving with no issues and then a few days ago out of no where when I was coming up to a red light I stepped on the brake to slow down. The brake pedal went all the way to the floor. I had to keep pumping the brake pedal to try and slow it down. The car slowed down however it did not come to a complete stop. I had to use my Emergency Brake to completely stop. I nursed the car back home (issues continued all the way) and I have not driven it since. I checked all areas where brake fluid could possibly be leaking from and have found no leaks. I have also continued to check the main brake fluid resevoir and the level of fluid has not dropped at all. I am trying to find out what is most likely the issue and/or if the recent brake booster repair could have anything to do with the current problem
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@cubanpete702 since your brake fluid level does not change you need to check the brake booster first and then the master cylinder. Check that the pushrods from brake pedal is mounted properly and that your brake booster isconnected properly to your master cylinder.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Victor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 369
