跳转到主内容
Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
624 个问题 查看全部
Why 031006 error code on my screen
How to fix code error 031006
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 31
14条评论
Have you check your Owner's Manual? How about https://epson.com/Support/sl/s. You will have to supply your printer model # there though, which is also a good idea to provide when asking in a help forum as all printers are not the same.
完成的
@alchain6003 what model is your printer and when did the error code show up? Anything done to or happening to your printer prior to?
完成的
Epson wf 7710 yes I refilled my ciss with ink primed put cartridge back when I turned on this error code wont go away
完成的
لدي طابعة ابسون 7710 كانت الفوهات مسدوده ففتحتها بمنضف وستعملت الطابعة وكان ادائها جيد وبعد يوم قمت بتشغيلها وضهرت لدي على شاشه الطابعة (خطأ في الطابعة اعد تشغيل الطابعة واذا ضهرت الحاله نفسها راجع الوثائق المتوفره لديك وبالاسف مكتوب هذا الرقم 031006) ممكن مساعده لاني حاولت اصلاحها ولم استطيع
完成的
The following information is being given regarding Epson error code 031008 is good to know about. I have sorted out this issue with the valuable guidelines provided. I have another small query regarding the error code 0x5. I am facing a huge issue regarding scanning. I have followed out the following steps as informed by the helpdesk
Fix Epson WF 3640 ADF Not Working. It is not working out. Suggest what to do for the solution.
完成的
显示更多的9条评论
添加一条评论
11个答案
已选择的解决方案
Epson error code 031008 generally occurs due to improper insertion of the printhead or ink cartridges. Accumulation of dust on these two printercomponents can cause this error code to appear. It occurs suddenly in between an ongoing printing session without giving any prior intimation.
UPDATE
Contact points
  • Make sure the cartridge chip is clean, free of ink smear and debris.
  • Make sure the printer's contact pin is clean, free of ink smear and debris
  • Verify that the cartridge is seated in the printer securely.  Push it down hard until you hear a click.  Once it is inside, wiggle it with your finger back and forth.  If the cartridge seems to be loose, insert folded paper to the back and thus push the cartridge forward to have good contact with the printer.
Installation
Possible Causes:
  • If you installed cartridge with power off, then printer won't know you changed the cartridge.  It will confuse the printer and thus cause cartridge error.
  • Sometimes Epson printer won't erase previous error code.  When it has a depleted OEM cartridge error, and a non-OEM cartridge warning come together, it causes the printer to display "cartridge not recognized".
Things to try:
  • Install non-OEM cartridge early.  Do not wait till OEM cartridges empty.
  • Put the OEM cartridge back and use on-screen prompt to change cartridges.
  • Power off the printer and leave it about 1 hour then power it on
  • Remove all cartridges.  Let the printer run without any cartridge.  It will create a "no cartridge installed" error and thus erase the "ink cartridge empty" error.  After the printer settles down, use on-screen prompt to change cartridges. A detailed tutorial can be found here:
  • https://www.bchtechnologies.com/blog/res...
这个答案有帮助吗?
得分 9
7条评论:
how about error code 031004 on epson L3110 ? Thanks in advance.
完成的
Renz read my answer
完成的
This is for error 031008 not 031006
完成的
Please help me fix error 031006 on wf 7710 printer.
完成的
完成的
显示更多的2条评论
添加一条评论
Here is the correect answer.
When moist, such as ink, creates a short circuit between two contact points in the printhead of the ribbon cable that connects it to the main board, then a small fuse on the mainboard blows. The error code the printer gives is 031006. The fuse on the mainboard is marked with F1 or F301 or something similiar. It is small!! I can’t tell you where it’s located as that is different for every different mainboard version.
Are you confident with a screwdriver and a soldering iron? Then you can do this and save yourself a $100 new mainboard. Take the covers off your printer, disconnect all cables off the mainboard, take the mainboard out, spot fuse F301 or similar and measure its continuity with a multimeter. If the meter does not beep: bingo. Replace the fuse, assemble everything, your printer works again.
If you found the fuse to be properly working, then don’t touch it and check all ribbon cable connections and clean all contact points between printhead and mainboard instead. https://www.youtube.com/watch?v=VoxwMqZN...
这个答案有帮助吗?
得分 9
1条评论:
This is best answer by far on this forum. Another forum poster Kevin BCH says it could be fuses F1, F2, F3 so check them all!!
完成的
添加一条评论
031006
MEANING="Head fuse broken error"
DESCRIPTION="- Printhead failure"
这个答案有帮助吗?
得分 8
7条评论:
Imexindo... so what we have to do to fix it?
完成的
I have the same error code 031006. How do I fix this? I heard on Youtube Epson does not sell replacement heads. I also found the same printerhead, an after market printerhead on AliExpress.
完成的
epson error 031006
完成的
Dear Sir/Madam
My Epson Printer Error code 031006 , WF-7715?
完成的
@manolosolis the main board requires replacement. The fuse labeled F301 on it has failed.
完成的
显示更多的2条评论
添加一条评论
Ok I think I solved this issue on two WF-7710 units with cg36 boards. The fuse was not F1 that failed. It was F2 on both machines. For anyone with a bad board caused by a bad print head make sure you check all three fuses on this board mine happened to be F2! I hope this helps someone.
Oh and if this happens it’s because of your print head, don’t reuse it! Get a new one.
这个答案有帮助吗?
得分 3
1条评论:
What type of fuse rating did you use?
完成的
添加一条评论
hi what mean error code 031006 epson 7720
这个答案有帮助吗?
得分 1
1条评论:
and epson 7710
完成的
添加一条评论
The 031006 is referring to a bad fuse on the main board. This is typically caused by a short across the print head ribbon connection due to ink/moisture intrusion.
The fuse is labeled F301 on the board and is not user serviceable; it will require the main board be replaced.
这个答案有帮助吗?
得分 1
2条评论:
I would not say it is required to replace the mainboard. I would say for most printer users it's not possible to repair it and they would have to bring the printer to an Epson service center. A new mainboard is an expensive way to solve a $1 broken component problem!
完成的
完成的
添加一条评论
I have a EPSON ET 4750 cleaned ink ports with Alcohol yesterday printer worked fine then kept telling me paper jam . Now I have error code scanner error code031006 to turn off. Have done this numerous times with no luck. Can this be fixed?
这个答案有帮助吗?
得分 1
1条评论:
You Need to replace the fuse and check/replace the strap cable to the print head.
完成的
添加一条评论
Hello everyone, my name is Wael Al-Massive. I have an Epson 7710 printer. When I turn it on, I get a malfunction code 033001 on the screen. Please help me so that I can fix it. Thank you very much
这个答案有帮助吗?
得分 0
添加一条评论
If your printer's status displays "Printer in error state," there may be a problem with the printer itself.
Make sure the printer is turned on and connected to your PC by Wi-Fi or cable. Check it for low paper or ink, and be sure the cover isn't open and the paper isn't jammed.
Greetings,
Peter
这个答案有帮助吗?
得分 0
1条评论:
This is an answer that does not add anything. Jammed paper, sure.
You give a generic answer that is not applicable to this range of printers and certainly not to this particular error code.
This error indicates that a fuse on the main board has blown. You can replace it is you are good with a soldering iron. Read my answer above for the details, thank you.
完成的
添加一条评论
ive got error code 031006 today on my xp15000. anyone know the problem is?
这个答案有帮助吗?
得分 0
添加一条评论
Its done! A fuse is blown on the board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alchain6003 将永远感激不已
浏览统计数据:
过去 24 小时: 47
过去 7 天: 207
过去 30 天: 1,006
总计 83,324
