跳转到主内容
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
494 个问题 查看全部
I have a 1980-1990 Ezgo marathon electric no power
I have a 1980-1990 Ezgo marathon electric no power I just replaced two batteries and cables the other four batteries hold charge my charger works I think a sometime the previous owner submerged it in water and does not run I’m stuck what should I check?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Does the solenoid click when you mash the pedal
完成的
添加一条评论
3个答案
最有帮助的答案
Brandon Moran  that will be a tough one since you are not sure of the history here. I suggest that you arm yourself with a multimeter and use something like this wiring diagram to start checking things out. One wire at a time. If you can narrow down the year etc. on your cart we can most likely find you more specific information.
这个答案有帮助吗?
得分 2
添加一条评论
wiring diagram 1982 ezgo marathon golf cart.
这个答案有帮助吗?
得分 1
添加一条评论
If it was submerged in water you might want to pull apart electric motor and clean rust off armature and check bearings for rust. I have had several of problems where i work. I deal with over 200 carts at a popular golf course in vegas. Good luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon Moran 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 77
总计 3,844
