跳转到主内容
The Jeep Grand Cherokee was redesigned for the 1999 model year; the 2000 models have minimal changes. This model is also known as Jeep WJ.
93 个问题 查看全部
Where is the fuse for horn and drivers seat?
Horn is not working
Drivers seat won't lower down in the front. Also won't move up or down. The back adjusts. Lumbar works and back part of seat will lower.
When I try the front and up and down it clicks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
novatay1 those things are not related by a fuse. the horn fuse is in the fuse box under the hood besides the battery. Fuse #18 is the horn fuse. You also want to check the horn relay and the horns. With all the adjustments you can do on your seat is is not a fuse that is a fault here. you said that “When I try the front and up and down it clicks “ so I would check the motor for the seat. The clicking is most likely the relay. You need a multimeter to test this. Here are the chapters that will help you with the diagnostics and repair Power SeatsHorn
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
novatay1 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 1,060
