跳转到主内容
加入维修社区 - 创建账户
尺寸为 9.5 x 12.5 英寸,型号为 ZE4530US,像素为 1024 x 768
cant get screen to work
I am trying to refurb an older laptop for my kid, screen is black I can hear the OS start but nothing is being output to screen. already opened the screen and checked all connections all look good and screen doesn’t appear damaged. next step???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
connect an external monitor
完成的
添加一条评论
1个答案
The next step is to troubleshoot the video subsystem.
First, look for an LCD cutoff switch or button on the laptop (some older models have this feature). The switch must be on for the LCD panel to work.
Use the laptop’s brightness function keys to increase the screen’s brightness.
If you added a graphics card to the laptop, make sure that the motherboard’s on-board GPU is disabled in BIOS/UEFI.
Use a port on the laptop to connect to an external monitor. Use the display function keys on the laptop to toggle between the original monitor and the external monitor. If the external monitor works, then use in to go to Device Manager and update the video drivers. If this works, great, if not then replace the inverter, and then the LCD panel of the original monitor.
If both the external monitor and the original monitor don’t work, then there is probably more than one problem with your system.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Lang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 234
