跳转到主内容
加入维修社区 - 创建账户
Xiaomi Mi A2(全球范围内也称为 Mi 6X)由小米于 2018 年 7 月发布,提供多种内存配置。它属于 Android One 项目,该项目保证提供两年的更新支持。
Random Locking/Unlocking - Hardware or Software related?
I bought my phone on eBay for cheap since it’s easily repairable and is equipped with “Android One” , the seller had already replaced the display and Volume up/down and power button flex cable inside the phone.
About a week ago the phone started locking and unlocking seemingly at random, doing it almost immediately after I unlocked/locked it by pressing the button myself.
First I shifted towards a hardware issue, corroded contact pads, maybe some water inside the device. Since a factory reset trough the recovery didn’t solve the issue it was clear it has to be the hardware buttons.
The big confusion for me now is:
When I boot it into it’s recovery and control the menu with the volume buttons the power button should press itself like it would with the lock/unlock issue, but it doesn’t!
Is there any known android software issue, maybe an app which is trying to inject a routine in the background that’s doing this?
I don’t want to open my phone, replace everything, close it up and see it starting to happen again because it’s software related.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If the issue disappears when you boot into recovery mode, then it is most likely a software issue. First try a full system update, and update all the apps. Try resetting all the phone’s settings back to their defaults.
If this doesn’t work, you may have to disable all the apps one by one until the problem goes away in order to find the offending app.
这个答案有帮助吗?
得分 0
添加一条评论
HI, I got the same issue, did you fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Florian Koch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 27
总计 1,169
