跳转到主内容
加入维修社区 - 创建账户
三星的旗舰手机,配备手写笔,是 Note8 的继任者,于 2018 年 8 月发布。具有 6.4 英寸显示屏和最高 512 GB 的内置存储空间。
Wrong file TWRP bootloop
Hi,
After install TWRP from Odin my Note 9 was stay on bootlop 'Samsung Logo' and restarting, i can't go to Download Mode and Recovery but phone only restarting bootloop.
It happend after install wrong twrp files (\twrp-3.3.1-1-star2qltechn.img.tar) i have select on Odin "Rebooting"
What's going now? Regards Thank you for help
Recovery and Download doesn't work, i can't going to him.... only restarting *****
video: https://streamable.com/k242c
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi Eda Ea, did you able to fix the problem , I faced the same one
由完成的 分享
Hi eda ea
i have the same problem
were you able yo fix your phone?
if yes, could you please tell us how?
thank you
由完成的 分享
添加一条评论
3个答案
最有帮助的答案
Turn it off full power off take cable out hold volume and Bixby whilst holding plug in USB
这个答案有帮助吗?
得分 2
2条评论:
After a failed attempt to remove the battery and ending up cracking the back glass, what you said was the solution. Just ONLY hold volume up and bixby, then plug in the USB. Thank you very much!
由完成的 分享
i cain't turn off my phone it just go off and on on logo after it's off i plug it in and it starts again. holding buttons doesnt help
由完成的 分享
添加一条评论
Hi Eda ea !
There is always a risk when ROOT a smartphone.
Did you try the recovery mode with the following commands :
Volume Up + Bixby + Power key together for a few moments
这个答案有帮助吗?
得分 0
4条评论:
I waiting for battery runs out of charge.  And push Volume UP + Bixby + Connect Cable USB, was starting to Samsung logo and bootloop…. i installed TWRP from other model (A6+) my misstake… and have select option in odin Nand Erase and Auto Rebooting…
由完成的 分享
Indeed, if the wrong TWRP model has been installed.
A reset factory will have to be done.
I suggest you consult this link: https://www.hardreset.info/devices/samsu...
由完成的 分享
Not possible it’s same problem….
由完成的 分享
If even this procedure does not work, I am afraid there is no other solution, unfortunately. Maybe another member will have a second solution.
Good luck with that!
由完成的 分享
添加一条评论
please help me i have the same problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eda ea 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 1,526
