What is CL error code on my top loading lg washer
What does the code CL mean on my top loading LG washer
@stevetheman LG Washer Error Code CL Fix. CL means that your washing machine's CHILD LOCK is ON. Since You did not give us a model number we have to give you the generic answer:
TO TURN OFF CL CODE ON NEWER LG FRONT LOAD WASHERS:
To TURN OFF CHILD LOCK on your LG washer, press and hold the CHILD LOCK button for 3 to 5 seconds.
The washer should now have CHILD LOCK mode DISABLED and all buttons will function properly.
NOTE: ON other newer LG front load washing machines hold the PREWASH/CHILD LOCK button for 3 to 5 seconds to turn CHILD LOCK OFF.
This method is for LG washers with inverter, direct drive, smart drum, and others.
TO TURN ON CHILD LOCK ON NEWER LG FRONT LOAD WASHERS:
To TURN ON CHILD LOCK on your LG washer, press and hold the CHILD LOCK button for 3 to 5 seconds.
The washer should now have CHILD LOCK mode ACTIVATED and all buttons will not function except the POWER button.
NOTE: ON other newer LG front load washing machines hold the PREWASH/CHILD LOCK button for 3 to 5 seconds to turn CHILD LOCK ON. from here
这个答案有帮助吗?
all of your answers are for *front**loading* machines/ the question is for *t*o*p**l*o*a*d*i*n*g* machines!!!
@wendy burchardt you are absolutely right. That is also why we ask for clarification about the model numbers etc. Commonly for the LG Top Loader (and Front Loader) CL means that your washers CHILD LOCK is ON. On some models you'll find two buttons "Temp" and "Options" in the panel. To reset your CL turn the washer ON and press those two buttons together for 3 seconds. Some models have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 5 seconds and it should work.
Thank you! It worked on my top loading LG!
THANK YOU! 1:30 am with a laundry room full of "kid just puked everywhere" blankets and I couldn't get the stupid machine to work! Old turkey you're a life saver!!!
What about for front loading dryers? Model DLE3500W. Please and thank you!
The op mentioned that this is a top loader and not a front load washer. The error code stands for Control Lock and to deactivate it press the control lock button for three seconds. It is located on the far right hand side. The bottom of four selections.
这个答案有帮助吗?
@bkups77 This was exactly what i needed thank you so much
Thanks so much!! I was freaking out because I thought my new washer was already broken. I just didnt see the control unlock button at the far right at the very bottom. Thanks for your help!!!
This solution fixed my issue
Sorry I missed this reading through the first time. Would have saved me about 20 minutes more of headache. Thanks.
Thank you so much for telling us where the button was on the front loader. I held the rinse and spin * Control lock for three seconds. That’s all I needed.
Deactivated CL error on my top loader by simultaneously depressing Rinse and Spin touch pads.
这个答案有帮助吗?
Hi @Jamie Finlay,
I cannot find any information online about a Swan SW158230b.
The nearest model number that I could find was for a Swan SW15840b and even then there is no online or downloadable user manual for it, which may have helped. (The Swan website shows no listing for your model)
The best that I can suggest is that you contact Swan and ask them for the information or for the user manual which should have the information how to enable/disable the Child Lock (aka Control Lock)
这个答案有帮助吗?
Hi @Jennifer Waldron
To activate/deactivate the CL (Control Lock) function in an LG WKEX200HBA, turn on the power and then press and hold the SOIL button for 3 seconds.
A chime will sound when the control lock has been deactivated.
这个答案有帮助吗?
Yay! Pressing the start button for 3 seconds on my botch worked! Thank you!
Hi, we had a similar sitch. I found the “key” for the codes inside the door area printed right on the unit. For us it meant “clean” as in time to clean. Hope it helps.
这个答案有帮助吗?
Thanks for taking the time to write Molly. I wish it was as simple as requiring a clean. Unfortunately, I've come to believe the CL stands for "Child Lock" and that is why the machine is frozen and doesn't allow for any settings to run. There's no "key" or kid's smiley face to indicate how to undo this lock and I've tried all the combinations of simultaneously pushing buttons suggested in the comments above and on the LG troubleshooting pages/video.
Still, nothing works - but I'm not surprised as the machine has been a disappointment from the beginning.
Thanks again Molly - Have a great day!
@Natalee-Jewel Kirby
What is the model number of your washer?
To turn on/off the Child Lock function in a WTG1034WF model, turn on the machine and then press and hold the Water Level and Spin buttons (both together) for 3 seconds and then release.
这个答案有帮助吗?
The number you posted i.e. MEZ41911003 is a serial number for the washer and not the model number.
According to LG the serial number may be applicable to any of the following models.
If your model is one of the following, to activate/deactivate the Child Lock (CL) function, turn on the machine by pressing the Power button and then press and hold the buttons indicated below for the amount of time shown
WT1501CW Soil (*child lock) button for 3 seconds
WT1901CK Soil level (*control lock) button for 3 seconds
WT7200CW Signal (control lock) button for 3 seconds
WT5720CW Signal Off-Low-High (child lock) button for 3 seconds
WT5480CW Water Plus (*child lock) button for 5 seconds
Note The child lock/control lock designation is printed on the machine under the relevant button
这个答案有帮助吗?
According to the user manual for your model, to activate/deactivate the Control Lock (CL) you need to press and hold the Extra Rinse button for 3 seconds.
这个答案有帮助吗?
It didn’t work. The tone comes on but no go.
Don't know if you tried this, but try disconnecting the power from the machine for 5 minutes after deactivating the control lock as described above and check if the washer has reset when the power is reconnected.
If still no good it may either be a faulty door lock (can you hear it trying to unlock when performing the unlock procedure?), faulty door lock sensor or a faulty control board.
Darn none of this worked. The machine can open and close. The top but as far as getting the CL button to reset it does not.
Not sure if this is like your model but here's a video that shows how the lid lock works.
Perhaps check if it is OK or not
Can't find a service manual for your model but with other similar models there's a switch or sensor in the lock that signals the control board whether the lock is closed or open.
Hearing the beep when you try to disable the CL sort of indicates that the lock is working OK. You did say that the machine opens and closes and mostly with a CL code you cannot open the lid, so I guess it may be a problem on the control board.
Here's a video that shows how to access the board in an LG top loader.
Hopefully there's a part number on the board as I cannot find a board for your model.
There's only one for a WT7150CW/00 (part # EBR86692719) and the board for it isn't compatible with your model or at least that's what 2 parts suppliers indicate when trying to verify if it is or not.
Wow, thank you for the time that you spent looking into this. It’s so helpful and yes it’s really frustrating. Both my son and I are trying to figure this out press every single button and we can imagine and plug the house pretty much and everything that we can imagine as I read this I’m at the laundromat doing my laundry, hopefully something will happen. Otherwise, I might have to get a new washer, but this is only two years old. Thanks again for all your help.
For front-loading washer dryer combo “Inverter Direct Drive True Balance” LG model #WM3499H*A:
Once LG is powered ON, go to the right touch-screen panel, press and hold “Pre-wash + Delay wash” buttons simultaneously for 3-5 seconds. This will turn OFF the CL (control lock/child lock). You’ll hear a little jingle when the function is processed. Similarly, pressing this combo again for 3-5seconds will turn back ON the CL .
Hope this helps!
这个答案有帮助吗?
I have a LG Direct Drive top loader
Model T2193EFHSKL
Please help😭
if you have a newer FRONT display. press and hold (Half Load + Energy Saver) together for 3-5 seconds and it should clear the “CL” display and wash the darn dishes.
这个答案有帮助吗?
For LG Direct Drive press and hold 'spin and Temp simultaneously for 3 seconds.
这个答案有帮助吗?
To unlock the LG ThinkQ Inverter Direct Drive Model WM4000HBA out of “CL” mode, you will need to look at the right side of the choices panel and press the Rinse+Spin/Control Lock option for 5 seconds.
这个答案有帮助吗?
Thank you so much!!!! I was thinking my washer was broken, and the manual was no help at all!
For my 10kg inverter direct drive i had to hold the water level and spin buttons simultaneously for three seconds to clear it. Finally worked after trying many other suggested combinations. Unfortunately, this was not in the manual.
这个答案有帮助吗?
Hi. Please how do I deactivate CL on my inverter Direct Drive 5kg LG front loader Model: F10C3LDP2
CL code means Child Lock. To unlock the LG ThinkQ Inverter Direct Drive Model WM4000HBA out of “CL” mode, you will need to look at the right side of the choices panel and press the Rinse+Spin/Control Lock option for 5 seconds.
这个答案有帮助吗?
Held rinse and spin for 5 sec, received a beep, however now I have dashes and door lock light is still on and door hasn’t released?
What is the model number of the washer?
Hi I have a direct drive 10kg top loader LG model is WTG1032VF child lock is stuck on and I can’t get it off could some one help please
这个答案有帮助吗?
Hi
Press and hold the Rinse and Hot Wash button for 3 seconds.
Oml you saved me !! Thank you been standing for 2 hours
Hold and press at the same time the Start button on the panel and the button above which the CL indicator is blinking (which is this button doesnt matter). Just hold these two buttons for 3-5 seconds together and the child lock will get deactivated.
这个答案有帮助吗?
How about a top loading model #MEZ41911003? THANK YOU!!!
According to the user manual for the washer (see p.28) to activate/deactivate the Child Lock feature, with the machine powered on, you have to press and hold the Water Plus button for 3 seconds
这个答案有帮助吗?
Hi @julie3257
Turn on the machine by pressing the Power button and then press and hold the Water Level and Spin buttons (both together) for 3 seconds to deactivate the Child Lock (CL) feature in the washer.
这个答案有帮助吗?
According to the user manual for an LG F14A8YD model, it has a dedicated Child Lock button, which needs to be pressed for 3 seconds to activate/deactivate the feature.
这个答案有帮助吗?
Try pressing hot water with one of the buttons at the same time. to see if the CL signal is removed.
这个答案有帮助吗?
Thank you for your response but it work used a paper towel and hot water to press on all buttons and it didn’t work.
过去 24 小时: 51
过去 7 天: 292
过去 30 天: 1,584
总计 257,399
49条评论
I had CL on my washer looked it up on here and found I needed to hold child lock button for 3 to 5 sec and it would clear it, it worked. yay
由 JESUS ESQUER 完成的
My top load LG does NOT have a child lock or control lock button or function.
I still have the CL error code.
my
model is 301PNVZ84959.
由 David Hillhouse 完成的
How to off CL for T2313NSAV
由 Tulip Matching Fair 完成的
I’m going to assume that you may have it by now but this should be helpful for future readers..... our LG front loader did not have a visible child lock button labeled anywhere but was stuck on the CL code. I decided to try the latch button that the door closes on and pressed that a few times and the code disappeared.
由 Shababa Muhammad 完成的
For the top load if you don’t see the child lock button, press and hold soil button until it clears for CL code
由 Namratha Kongovi 完成的
显示更多的44条评论
