跳转到主内容
加入维修社区 - 创建账户
这款 LG Tribute 智能手机的型号为 LS660。该设备于 2014 年 10 月发布,搭载 Android 操作系统。
Phone stuck on Android is starting screen
Phone was shut off Durning a factory reset when it was turned back on it went to Android is starting starting apps in a white box with a blue circle going non-stop for days. So did another factory reset this time it went all the way through it little Android dude came on it restarted went to same screen with white box and there it sits with that blue circle spinning. PLEASE HELP
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
已选择的解决方案
If your phone is fully charged, then you can try contacting the manufacturer or service center
这个答案有帮助吗?
得分 2
1条评论:
If stuck at "android is starting"
Do the following:
1. Start the phone in safe mode by press and hold power button, a list comes press and hold shut down button, chose safe mode
2. Once in safe mode; from setting options turn off safe mode; press it phone restarts; voila
由完成的
添加一条评论
最有帮助的答案
Check your settings when I went to my settings I investigated that there was no home launcher app selected
Wierd… even there was no manufacturer set launcher app
But my phone is still functional
I could still go settings and scroll my notification bar and I realized my phone had a “ultra power saving mode launcher” which is bit like Samsung's but different it allows u to use apps that a lot of power consumption so I used that to access my apps
When i thought why don't I download a Android launcher… and then it worked I applied it as my default launcher and my phone no longer says “Android is starting” no longer a problem!
Phone : Alcatel 1c (2019)
Hope this works for you…
Search for the internet “how to fix stuck startup screen via ADB” as well if your familiar with the ADB tool for pc
There are communities that will help your problem via using ADB command line to fix this issue
https://developer.android.com/studio/com...
https://www.google.com/amp/s/www.makeuse...
这个答案有帮助吗?
得分 5
6条评论:
I tried everything and this is what worked!!!
由完成的
Worth noting that you can remove the default home app under settings for Apps -> default apps purely by accident on kids devices using google family link and parental controls. Not all home apps seem to register as unblockable system apps under family link. Luckily they ARE system apps at least in my case and removing the app block + rebooting allowed me to select it again under the default apps setting because it was never actually removed. Maybe this helps someone :)
由完成的
Black Ace, you're a genius. I accidentally disabled the Home launcher in Google Family Link.
由完成的
Black Ace!!!! Yes!! Thank you so much!!! I was losing my mind over this issue!! And you were totally right about this! As soon as I removed the block from the home launcher....the android starting left and everything came back up on the other phone!!! You are a life saver!
由完成的
Omg tysm. Somehow home was blocked on the family link. Unblocked it and it immediately fixed. I tried for days to figure out what was wrong tytytyty
由完成的
显示更多的1条评论
添加一条评论
This is a common issue you might face while force restarts on a hard reset period. Actually, while hard resigning the Android system create a temporary cache partition to store information and all. A force restart or restart due to the low battery can lead to the dead screen. No matter which Android you are using. You can simply try clearing the cache. you can press the volume up+ power button and select wipe cache partition. once wiped, then try hard resetting the phone. Hope this may help. You can google for how to wipe cache partition on Android. Also, try booting the phone in safe mode to ensure the problem is related to software and not a hardware component.
这个答案有帮助吗?
得分 0
添加一条评论
it happened to me , i kept the phone on power saving mode. i undo the power saving mode and it worked!
这个答案有帮助吗?
得分 0
添加一条评论
Phone died so I went to plug it up for a few hours. Went to power it on like normal and noticed it would get stuck on the boost mobile screen while powering on. It works powering off but it just does the same thing over and over. Stuck on a black background with the boost mobile logo and the words 4G LTE nationwide at the bottom. this is not my phone and I'm supposed to give it back to its owner first thing in the morning PLEASE HELP
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
michelle leonard 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 38
总计 19,097
