跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Battery replacement odd behavior
Hello IFIXIT community,
I recently bought the MacBook Pro replacement battery kit that IFIXIT provides to their customers so they can do Apple’s job at a cheaper price. I was able to install the battery with no issues at all.
But, after a day, while using my computer after calibrating the battery for better results I decided to restart the laptop for some testing not related to its battery life. Before I rebooted, the machine life was at 69% but after turning it back on, the battery was showing me a 6% battery life which is super odd and insane at the same time.
If there is anyone that experienced this with their replacement and/or noticed but went away later after constantly using the machine, please let me know. I am an IT guy myself, but I do want to make sure I am not the only one that has seen this odd behavior on a computer.
I hope that somebody can share any thoughts and or a solution to this. In the meantime, I will disconnect the battery adapter and put it back in just to see if it is just a mistake I made.
Hope somebody answers soon. Cheers community!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
9条评论
Please post a snapshot of CoconutBattery so we can see the batteries status 在已经存在的问题里加入图片
完成的
Hello Dan,
Thank you for commenting on my post. I have edited the content and the image should be now displayed. To me everything looks fine on the battery, also checked other battery apps while waiting for this response last night. Is there anything in mind that could be causing this?
完成的
@danj Today while using two different battery use checkers or whatever you want to call them, I noticed that they provide different numbers from the battery's charge for example:
The mac battery shows 73% and so does the app "Battery Monitor". While coconut battery shows 67% and the mac battery shows 73%.
Do you have any idea why this could be?
Thank you
完成的
@poporobright Coconut battery always shows a lower percentage except for when battery is fully charged.
完成的
@arbaman - Correct! This is mostly do to the lag between the OS call to SMC from the app and its reply. Unlike the OS's native access to SMC.
完成的
显示更多的4条评论
添加一条评论
1个答案
已选择的解决方案
The CoconutBattery output looks good!
Its what I would expect. How about cleaning the MagSafe connections in case your one-wire sense line was not making good contact. Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure the cable is not damaged in any way, also make sure you have a real Apple charger! There are many fakes out there that will damage your system OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth.
See if after cleaning the connections and if needed a replacement charger fixes things.
这个答案有帮助吗?
得分 2
3条评论:
Hey Dan,
Thanks for all the support. I got this mac charger from my tech company so I genuinely think it is a true mac charger. Also, I will clean the port and see if it keeps changing and or getting better while I continue to use it.
Will keep you posted .
Thank you
完成的
@poporobright If the Mag-Safe does not have an Apple logo stamped into both sides it is a knockoff and may damage your Mac
完成的
@mayer thank you for the info!
完成的
添加一条评论
添加你的答案
Daniel Mazariego 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 107
总计 574
