跳转到主内容
Repair guides and support for your Sanyo TV.
360 个问题 查看全部
over bright and uncontrollable bightness and contrast Sanyo LCD TV
My TV is Sanyo LCD 42-S-10. At switch on good sound and picture,after 3-5minutes
the picture is over bright even when brightness/contrast bar is at zero.Kindly help with
what needs replacement
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I have found that understanding the Difference between the Brightness and Backlight of your LCD is key to adjusting your television to the best preferred lighting. While the "Brightness - changes the colours of the pixels on the LCD screen. ... the Backlight - is the intensity of the fluorescent lamp behind the screen that makes the picture more intense. If you’re setting for brightness is set at the lowest level, check the level on the backlight to be at a minimal setting to reduce the intensity of the actual screen picture.
这个答案有帮助吗?
得分 2
添加一条评论
@wimcy sounds like an issue with the gamma correction on your T-con board. Check that first be either checking the actual IC or replace the T-con board.
这个答案有帮助吗?
得分 2
添加一条评论
the picture is really hazy looking and i don,t have a remote and there are no knobs for contrast or brightness?>
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Willy K Gikaru 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 788
