跳转到主内容
华为在2019年3月份发布的一款旗舰机,它拥有一块6.1英寸的OLED显示屏并带有屏下指纹传感器。
83 个问题 查看全部
Can I change an imei number
Can anyone assist me with the below item.
Server Error in '/' Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->  <configuration>     <system.web>         <customErrors mode="Off"/>     </system.web> </configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<!-- Web.Config Configuration File -->  <configuration>     <system.web>         <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>     </system.web> </configuration>
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@phemelo there must be a reason why you would want to change the IMEI number (yes it can be done on some of the Android phones) Where the IMEI is used to trace the location of a device or find the stolen device, on the other hand its used to make a device untraceable by changing its IMEI number, serial number…etc. so you see why this is not going to be an easy answer.
这个答案有帮助吗?
得分 2
添加一条评论
Yes, it’s possible to change the IMEI number on any cell phone models. To do this it’s possible only using Box Tool. This tool depends on the device phone model. For LG is Octoplus. For Samsung, you have Z3X Box Tool. You have here full guide and tutorial how to download this software for free and full instructions on how to use https://www.unlockbasecodes.com/how-to-c... very easy.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Phemelo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 4,815
