跳转到主内容
加入维修社区 - 创建账户
这是iPad mini 3(型号A1599)Wi-Fi版本的维修指南。这款iPad在2014年10月16号作为iPad Mini Retina屏版本(现在也称作iPad mini 2)的新一代被发布。
Again: Digitizer Replacemtn / Home Button issues
Hi,
i replaced the Digitizer on my ipad mini 3 and am left with theTouchID issues and non-working Home-Button and Touchscreen.
I did not throw away the old Home-Button, but i did cut the Flex cable since i was not aware of the issue when i started changing the digitizer.
Is there any way i can repair the issue? Is there any way to get to the data stored on the ipad? I would not mind to much switching to another tablet, but i need the data on the ipad…
Best regards,
Tobias
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
you do not need the touch iD to work to get the iPad working again
Buy a new digitizer with a home button and fit it
这个答案有帮助吗?
得分 0
2条评论:
The Digitizer i currently have is a new one, because the old one was shattered.
I now got rid off the error i had previously being shown on the start screen (TouchID can not be activated on this iPad), but HomeButton and Touchscreen are still not working
由完成的
Just because it is new does not mean it is working>> You need to test it with one you know works
由完成的
添加一条评论
the connector on the motherboard are probably damaged and needs to be fixed. if you look closely on the golden pins can you se if any are bent or missing? They are quite fragile and removing the screen can easily rip them of
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tobias Mueller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 374
