跳转到主内容
The production third generation Quest was unveiled for the 2004 model year at the 2003 North American International Auto Show.
8 个问题 查看全部
04 quest van limp mode and no electronics
Working on a 04 quest. My first stupid mistake was not disconnecting the battery. I was changing the O2 sensor and the rubber boot on the alternator slipped up and the socket grounded the positive lead to the alternator. There really was not a spark, but there was a quick puff of smoke. And a slight pop from the battery I believe. The van starts but no electronics work except for the display. And a bunch of dummy lights are on. In park full throttle only revs up to 2k rpm and in drive or reverse on flat surface will accelerate but if I encounter a hill lit will not go up. Reverse is the same. No acceleration. Looks like the fuses are all good. Would the grounding out the positive wire cause the alternator to go bad? Which in turn make pretty much everything not work since the system is pretty much all electric? I have hooked up a code reader but there are no codes that have to do with electric. Needless to say I still need to replace the O2 sensor. Thank you for your help.
Update (08/05/2019)
Ty for your quick response. But I was able to figure out the problem. There are a few in line fuses on the positive battery cable at the battery terminal. And the 40amp fuse was blown. I have also replaced the 02 sensor.
are a couple images.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@reunion try to reset the ECU:
  • Turn the ignition key to position “ON” without starting the engine and wait 3 seconds.
  • Fully press and release the accelerator pedal five times within 5 seconds.
  • Wait 7 seconds
  • Fully depress the accelerator pedal all the way to the floor and hold for ten seconds. until the CEL starts blinking.
    • At this point the light CEL should start flashing error code stored in the system and you can release the pedal. If you only get five flashes slowly or not flashing at all, then it is time You went on one of the above steps and you have to start from scratch.
  • Fully release the accelerator pedal (while the CEL is still blinking) and wait about 10 second.
  • Fully depress the accelerator pedal and keep it for more than 10 seconds.
  • Fully release the accelerator pedal (The CEL light will continue to blink).
  • Turn the ignition off and start the engine to verify the indicator has been reset.
  • What concerns me is the puff of smoke. Have you check the area where you seen it come up to identify any parts etc.? If unsure post plenty of picture about location etc. so that we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
nate 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 95
总计 6,589
