跳转到主内容
苹果出品的高性能平板电脑。
740 个问题 查看全部
Changing screen and lcd
Hi, I broke my ipad pro 12.9” screen model a1670. If I buy the new one that offers fullset, will my touch id still works? Because if I have to do some soldering, I don't have the abilty.. Someone says that the ipad pro middle flexible locaten on the screen is crutial so we have to include the old one to the new one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
In order to retain touch ID functionality, you need to salvage original home button from broken screen and transfer to the new one.
Buy a replacement screen with daughterboard pre-installed (‘the middle flex’ circled in picture) to save yourself the hassle of soldering, from any reputable vendors like iFixit and MobileSentrix.
Follow this guide for disassembly of device: iPad Pro 12.9" Screen Replacement
Follow @refectio guideline in his answer to this post for re-assembly: After doing my repairs (battery and screen) I have problems
这个答案有帮助吗?
得分 2
3条评论:
Does the picture I posted is the correct display for the ipad rpo 12.9 a1670? Or is it for the a1671?
完成的
@Nic Yaakov Durant, Sr A1670, A1671, and A1821 are three model numbers for iPad Pro 12.9" 2nd Gen, they use the same screen assembly. I can't really tell which one you have just by looking at that picture.
完成的
Hello sammyz I currently have an iPad Pro 2nd gen 12.9 A1671. I sent about two emails regarding this issue and they just kept telling me that they didn’t know. And last night I got another email saying that the part I had picked out that cost about 399$ (Item code IF323-030-1)is the one that includes the daughter board. However, he is not sure if additional soldering will be required. I want to fix it really bad because I use it to take notes at UNI. But the little cracks get in the way. My Apple Pencil rubber tip is like gone now. Hope you can get Yours fixed Nic D. And if you do LET ME KNOW PLEASE!!!
完成的
添加一条评论
添加你的答案
Nic Yaakov Durant, Sr 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 184
