跳转到主内容
加入维修社区 - 创建账户
微软于 2015 年 10 月发布的二合一笔记本电脑键盘。搭载第 6 代 Intel Core i5 或 i7 处理器。
Keyboard battery not charging
Out of the blue, battery 2 (the battery located in the keyboard) stopped charging and is now permanently at 0%. When the Surface book and the keyboard are connected bettery 1 (the battery located in the screen is charging normally).
I tried replacing the battery in the keyboard, but it didn't help. What do you think could be the solution? I tried to find a replacement GPU board without success.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论:
Hi Luca, I have the same issue. Did you manage to find a solution?
Thanks!
Constantine
由完成的
Nope. It needs a replacement of the logic board inside the keyboard. Couldn't find a replacement logic board and a new keyboard is expensive considering that it's an old machine. You find from now and then second hand keyboards around, but didn't bother to look for it actively.
由完成的
添加一条评论
3个答案
Hey. I’m not sure what you mean by gpu,but as long as the surface tablet works fine,you can probably get a new keyboard. It’s really down to the possibility of a power management issue in the keyboard. This can be a loose connection somewhere,a damaged component,etc. You may want to look into buying another keyboard for it.
这个答案有帮助吗?
得分 0
添加一条评论
As an electrical engineer i am trying to hunt down a similar problem. i have an undesirable voltage on my battery cells and my laptop charger is not propagating through the board. so i am trying to go through the chips to make sure things are turning on but some how 15V is creating a 3.3V rail. but my input protection mosfets are not turning on to allow the 15V to go to the battery charger.
这个答案有帮助吗?
得分 0
添加一条评论
Ok I have the same issue that the keyboard stopped working, so (don't laugh) I pulled the keyboard of the surface, spit on the terminals and rubbed very hard to kind of clean them, and walla my keyboard now works.... :-) Hope this works for others its worth a go...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luca Vicini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 43
总计 5,635
